Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: EGR valve update
    Cambridgeshire
    Default EGR valve update
    Well I installed the last of the restrictor plates for the EGR valve on my 1.9 CDTi (16v). I've had one restrictor plate (EGR to manifold) since November time with no running issues. So I thought I would go all the way and fit the other one for the other side (to restrict the gases that enter the EGR).
    Since fitting it I've taken it for a spin up the road and I can definitely say (hand on heart) that there is an improvement in the throttle response, loads more grunt below 1500rpm too
    What I will do it keep this up to date with any more changes that may occur along the way. I fancy getting mine on the rollers soon before mapping it to see if there are any changes
    Thanks for reading.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    No EML then..?
    Looks like I will get one fitted too, cheers for the update
    Cambridgeshire
    No EML then..?
    Correct, so far no lights on dash and all running smoothly and more responsive
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Good to hear that the car is running well. I have also got that first plate installed and found it made a difference. Do you have the part number for the second diamond shaped restrictor ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    This is a mod Im gonna do in the next couple of weeks, is the gasket that fits between on exhaust to egr available from Fiat too?? I heard you only get the one that sits between the EGR and manifold?
    Gazza4
    Jan 2010
    Doncaster
    makes you wonder why vauxhall put these on in the first place if all ppl are guna do is blank em out?? cant all be good surely? may-be exhaust emisions arnt so good after?? any clues???
    Cambridgeshire
    Yep you can get them both from Fiat. One is listed as being for the 150 and the other for the 120. If you get both then you can fit the '120' one on the exhaust to EGR side
    Vauxhall fit them so that they pass the Euro emissions test when newly built. Only problem is (as we've all noticed) is that it does the inlet manifold no good what so ever
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Greg-w- View Post
    Quote Originally Posted by parsco View Post
    Cheers Parsco, I spoke to a garage about them and said they just 'switch the valve off' as they were causing so many problems.
    When you think about it especially in the 150 they are a fairly awkward design for gas flow and allowing the soot to build up.
    Gazza4
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Gazza, can you give details about the garage that will switch them off, my normal dealer won't but if there is one not too far away, I'll go and visit them.
    Thanks.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    This is really starting to anoy me now that I cannot fit even the big plate without the EML straight away!!!..
    I have a new Inlet and would love to fit this (both of them) - DAM!
    How can I get this sorted as I am sure its related to the Software... grrrr
  1. dump valve update after a week
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2011, 08:31
  2. 4 months on after the New EGR Valve was fitted - update
    By Vaux-Man-G in forum Diesel Engine related
    Last Post: 30th September 2010, 19:52
  3. Replies: 17
    Last Post: 15th December 2009, 14:53
  4. Power Loss Update! No new EGR valve needed (yet!).. all coz of Vectra C.com!
    By nickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2008, 18:22
  5. egr valve update!
    By littlesxi in forum Diesel Engine related
    Last Post: 18th March 2008, 22:13
