Results 1 to 3 of 3
Thread: Aalarm wiring diagram please
    Berkshire
    Default Aalarm wiring diagram please
    Hi guys
    Does anyone out there have a wiring diagram for the standard Vec C alarm system?
    I have fitted an aftermarket alarm to my car because I needed a proximity alert and pager system (unfortunately I work with the hoody brigade and it seems its a requirement). The problem I have is wiring the lights up without running huge amounts of wiring through the car and thought it may be easier to wire it all into a central point and 'plumb' into the existing wiring loom.
    Is this possible?
    I am aware of the Vec monitoring everything and consequently I have wired this one independently so far and tapping into the fuseboxes in the front but I have come to a little bit of a dead end.
    A central point for lighting would be good as an alternative.
    My Vec is a 2004 2.0 Diesel, Half Canbus system. Any guidance would be very much appreciated.
    Thanks guys
    Exx
    Berkshire
    can anyone at least suggest a central point to wire into the indicators? perhaps at the hazard switch or the hazard relay?
    Oct 2007
    Shropshire
    I don't think there is a central point, the indicators are no longer controled by flasher relays, it is done by the computer. The hazard switch just sends a signal to ecu to turn the hazard on and is not really actually part of the indicator circuit!! I would say the easest way would be the tail lights??
  1. please help req a wiring diagram
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 18th May 2012, 22:01
  2. wiring diagram help
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2012, 09:52
  3. Wiring Diagram
    By Chris4122 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 12:20
  4. wiring diagram
    By johnrolfe in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2008, 00:37
