Results 1 to 10 of 11
Thread: P0422 error comes up again and again
    New Member Oski's Avatar
    Poland
    Angry P0422 error comes up again and again
    Hi guys.
    I did a search through the forum, but I didnt find a clue. Some time ago I replaced a catalyst converter as my old one was simply jammed. But since that time, several times a week I got a spanner icon, which is related to p0422 error code - Main Catalyst Efficiency Below Threshold (Bank 1). Am pretty sure CC isnt faulty and have no clue what's wrong. I have oxygen sensor, the one just after CC, but dunno if it can make error mentioned above to come up? Did anyone have the same problem? I just dont want to replace every single part of exhaust of my car. Almost forgot to mention: the error comes up mostly when I use auto selective mode (had AGB). Engine Z32SE. Am able to clean the error code using an opcom interface but it comes up again after some time. Beside it - car is fast as a rocket, drives smoothly. But that spanner icon is such annoying. Any ideas mates?
    Bristol
    Vehicle : CDTI 150
    Basically the post cat O2 sensor monitors the efficiency of the cat.
    With a known good cat I would first check the wiring from the sensor to the main loom then as a cheap option replace the post cat sensor; would also buy a specific as opposed to generic one.
    Full Member Big Sig's Avatar
    the 3.2 has 3 02 sensors and 3 cats. I would look at the pre cat and the sensor on bank 1.
    Poland
    Quote Originally Posted by lesj View Post
    The wiring seems fine, I didn't find any damage on it. So may it be sensor itself?
    I know it I meant the one on even cylinders' side, which was changed some time ago Am sure it works fine. Been just wondering if the faulty o2 sensor may cause that error code to come up?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    you'll just have to try the after cat sensor but they normally are correct and non-gen cats aren't up to the vx tollerances
    Poland
    Quote Originally Posted by mattv6diesel View Post
    I bought the cat from Opel/Vauxhall dealer.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by Oski View Post
    they have changed the correct one ie bank 1 or 2?? might just be the sensor then but take it back and complain
    Poland
    Yes, they have. I had a problem with misfiring and found it was the cat on bank 1 - was simply jammed (besides: mil indicator was lighted up or even flashing). I took the car to Opel dealer, they changed the correct one and misfiring problem had gone. But now I have this issue with 0422 error. I'll do what you say - I'll change o2 sensor (i'll try to have a chance to give it back if swap doesn't help). Matt: i cannot complain - simply because they did it free of charge (i have a friend working in Vx dealer) and i feel it'd be not quite fair to complain.
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Hi all, did you ever get to the bottom of this? i have a 3.2 and recently i have had the same code coming up every oher day. i was hoping to try other things before having to change the cats.
    Many thanks,
    EVERYWHERE
    3.2s still get through MOT without a 'cat'.
  1. P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    By winty234 in forum Engine & Drivetrain
    Last Post: 8th May 2016, 13:33
  2. DAB box error
    By carlton in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2016, 08:55
  3. DAB box error
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:30
  4. which error?
    By steve1412 in forum Engine & Drivetrain
    Last Post: 9th February 2011, 20:00
p0422 3.2 signum
