Thread: barometric peasure sensor any1 know were it is??
    Apr 2009
    stockton-on-tees
    Default barometric peasure sensor any1 know were it is??
    does any1 no were this is aswell as the boost sensor my dealer doesnt seem to no where it is i thought it was near egr valve and apart of the egr cleaning how 2 ??
    Apr 2009
    stockton-on-tees
    bump
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    If its a vectra your on about its the little sensor by the drivers strut top mounted on a plate with plug attached.
    Apr 2009
    stockton-on-tees
    ive got a 2.0 dti if its the same is it mounted to the airbox?
    Stockton on Tees
    its a small sensor near the strut, but if you put the car on a diagnostic it might be wrong. My 2.0DTi came up with this fault but its the EGR valve all carb'd up!!! Gave it a clean and the fault magically disappeared!! If it is this part i've got one (as i fell for the diagnostic trick!!) that you can have for £15. I paid £45 from VX but don't need it. Give the EGR valve a clean first as this cost nowt!!!
    Steve
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Take off thhe top plastic engine cover and sensor is located on top front right hand side under the cover. 1 bolt holds it on.
    Apr 2009
    stockton-on-tees
    thats the boost sensor isnt it?? not barometric sensor?
  1. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  2. p1105 Barometric Pressure Sensor problem
    By stuarty1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 08:34
  3. can any1 show r tell me were the maf sensor is on a 2005 1.8 thnx
    By wallace78 in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 15:34
  4. Where is a barometric sensor 2.2dti?
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 08:57
