Thread: egr quick ?
    grimsby
    Default egr quick ?
    took egr off me cdti 150
    it is caked with cr*p going to lean it
    also notices the manifold it connects to is almost blocked managed to scapped out about a golf ball size of gunk what the best way to clean the rest of ?
    cheers
    Regular Member P3tchy's Avatar
    Milton Keynes
    Take it off.
    Throttle body is probly blocked up as well.
    grimsby
    how easy is that mate
    Milton Keynes
    Not very, I replaced mine as the swirls were knackered but the old one had about 10mm of crud all round the inside.
    grimsby
    should i have 2 gakets or 1 when i remove the egr valve doh
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    2, ONE SQUARE I OVAL. although the square one tands to stick on the egr or the manifold and can be missed. the oval one can sometimes drop down into the engine bay if it was'nt noticed when you took it apart, pic here.
    http://www.vectra-c.com/forum/showth...=104274&page=2
    grimsby
    mine only had 1 the oval one guess best go to dealers for the square 1.just built it back up it runs ok engine management light came up a couple of times could that be the missing gasket
    grimsby
    cleaned the egr valve up fully put back in but after clearing fault then running engine up after 2-3mins same fault code comes up any idea what i should try next or is it just fit a new egr valve.the old one is nice and clean now and the valve is free.but it does not have a gasket do you think that could be the problem now
    cheers
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Is the linkage connected properly & moving moving ok?
    grimsby
    yes when i cleaned it i checked the valve and it move freely
  1. Quick help plz
    By messsy in forum Engine & Drivetrain
    Last Post: 4th July 2012, 23:06
  2. Replies: 7
    Last Post: 12th October 2011, 10:24
  3. Quick wash & Quick Mods
    By ilovetechno in forum Quick Photo Album
    Last Post: 3rd October 2011, 19:40
  4. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  5. Quick Help
    By DarylAAS in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2010, 11:10
