Thread: Spanner light for nothing?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    confused Spanner light for nothing?
    Got the spanner light up but car starts and drives as usual.
    I've noticed however that the emisions light doesn't come on when I turn the igniton on. Related, perhaps?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Sounds like mine but the emisions light is fine
    Full Member Big Sig's Avatar
    May it not be an engine problem??
    The emissions light should only come on if the car has DPF
    Mine has never com on
    Are you getting just the EMS light, the EML light, or both?
    If just the EMS light is on, then the camshaft sensor may have failed and for this the engine does not normally go into safe mode (so long as the EMS is still receiving a signal within tolerance from the crankshaft sensor)
    Typical life of these sensors is about 2 years / 40K miles, so it can be wise to replace both at the same time
    However, the code should be stored, so if permanent arrange for it to be read
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The emissions light (near refuel light) came on numerous times on mine when I had a bad EGR.
    If any sensor is within parameters it will not generate/light up the spanner thing, but as I discovered a while ago a fault code might still be stored (on OPCOM, NOT Tech2!!!)
    I'll plug the car in on Monday to see what's what.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
