Results 1 to 10 of 17
Thread: Squeaky Heater Fan-Advise Please
    Lincs
    Default Squeaky Heater Fan-Advise Please
    I have just fitted the new heater resistor and have all 4 speeds now, thanks for all previous advise on that.
    However i have an annoying squeak now, most noticeable on 1. Is there anything i can get to to oil/lubricate it?
    I also notice the heater controls don't function on just feet only. I get a small draft on the feet, but most goes to the screen even though it's on feet only(turned right across to right). When i turn the control to alter the direction i can hear it moving, but no noise when i turn to just feet only. Any tips would be great thanks.
    Thanks in advance
    Paul
    Full Member Big Sig's Avatar
    Could be a servo motor that is no longer working. They are located behind the panels in the footwells in the centre of the car. Remove the pollen filter and try to put a few drops of oil in there the bearings are located. Its probably a bit rusty from water ingress thats likked the resistor pack.
    Regular Member suggs1971's Avatar
    east cleveland
    I had the same prob last year when i replaced the resistor pack, squeeky motor, i took the pollen filter out and sprayed a bit of wd40, was a bit pongy for a couple of days but still not squeeking.
    Lincs
    I did spray a little WD in there, but maybe i need to blast it then.
    Cheers.
    WD40 isn't really an oil, its a penetrant spray. 3in1 is better
    Lincs
    Yep, removed pollen, 3 shots of 3 in 1 and for the last couple of hundred miles i have been squeak-free
    And i still have 4 fan speeds.
    Cheers.
    east cleveland
    Nice one m8.
    leicester
    Hi there i have the same problem i used wd-40 and 3 in 1 and its still making the annoying sound. Any other advice please it only makes the sound in 1 and 2 i think the blower sound overcomes it on 3 and 4. PLZ help as it is reallllli annoying.
    Newcastle upon Tyne
    I had the sasme problem used wd40 and 3in1and was still squeeking in the end squirted about half the can in the little ****** that did the trick, just remeber to drive with windows down for a couple of days!
    leicester
    in the little? whats the ******
  1. squeaky fan
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 22:12
  2. Squeaky rear end!
    Last Post: 18th October 2008, 01:46
  3. Squeaky Door...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 21:53
  4. Squeaky Rear
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 20:28
  5. Squeaky suspension
    By James C in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2006, 22:27
vauxhall vectra squeaky heater fan
vectra c squeaky fan
squeaky heater fan vectra c
