Results 1 to 10 of 14
Thread: twin exit exhaust
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default twin exit exhaust
    hello folks, i have a query for you guys, i'm looking to buy a second hand twin exit exhaust from a 2.2 direct to fit to my 1.8 sri 2006 reg, what i need to know is will this fit straight on (from the cat back) without any drama or is there any difference in the bore size etc, etc ... i know the hangars etc are already on my car for the twin exit and i also need to get the twin exit diffuser for the sri, but will it go on hassle free or is the anything that'll turn it into a headche, thanks for the help in advance
    Aug 2009
    Bump
    Aug 2009
    Anyone
    Regular Member connery-sri's Avatar
    Basildon, Essex
    I am new to all this, but take a look at this. http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    It might be the right part.
    Was gonna go for it myself but need some other exhaust parts doing so gonna get a full system @ MIJ.
    Hope this helps
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    I have not seen a vec c exhaust looking like that before
    I have just converted my 2.2 DTi to a twin exhaust. I bought a second hand twin system from a 2.2 petrol and it was a straight fit.Same bore etc.
    Hope that helps
    Jon
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by blues n twos View Post
    Hope that helps
    Jon
    It's not a Vec exhaust, its a signum exhaust, it won't fit a Vec
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    According to EPC that Y shaped exhaust rear end assembly would be the Vectra C Estate/Signum one (same item).
    The listed mid-section pipe assembly for Z22YH engine is 24454037
    The listed mid-section pipe assembly for Z18XE, Z18XEL engines is 24447474
    Whether the 1.8 mid-section will physically fit to the 2.2 LH (24422146) & RH (13156933) rear sections, I can't tell you.
    No LH + RH assemblies appear listed for 1.8 engines.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry your right, but it won't fit the hatch/saloon
    Aug 2009
    the one i'm after isn't the one listed above, has anyone actually fitted a twin exit exhaust to their 1.8, i need to know if it will fit straight on, the one i'm after has come off a 2006 2.2, mines a 2006 1.8 sri, will this exhaust fit my car without any hassle, donor car and my car are both hatchback, identical except for engine size
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm getting the feeling you might be the person to find out if the 1.8 and 2.2 exhausts are in any way physically interchangeable. At least if you get the 2.2 system off you can then take measurements for bore diameter and parts lengths then compare them against the 1.8.
    If you find they will swap, then you win. If you find they won't, then you have a 2.2 exhaust I'm sure someone will have off you for a decent price. Either way you win.
  1. For Sale: Twin exit Exhaust
    By KeefyB in forum Parts for sale
    Last Post: 28th September 2011, 20:25
  2. Twin exit exhaust
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 23:12
  3. Twin Exit Exhaust
    By Matt&Jemz in forum Parts for sale
    Last Post: 12th September 2009, 09:18
  4. vectra estate twin twin exit exhaust
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2008, 12:25
vectra c twin exit exhaust replacement
