Thread: Urgent help needed re. glow plug relay
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Urgent help needed re. glow plug relay
    Morning all,
    As you may be aware my Vec is currently for sale. A day before someone is due to view the car the EML light comes on. The fault code comes back as being the glow plug relay. Having changed this the code clears for 24hrs, before reapearing.
    Voltages across all gloe plugs etc are correct, and my mechanic has checked all circuits.
    Anyone any Ideas?
    There are no faults in the way the vehicle drives. If it wasnt for the light you wouldnt know there was an issue
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I know its only been half a day and most people will be at work, but getting a bit desperate so
    Bump
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    It's probably not a lot of help, but if you've changed the relay and it clears then comes back again, it would suggest that some other problem is nackering the relay... which means it's not necessarily the relay that was broken to start with....
    I may be stating the obvious here, but I HTH
    Stuart
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    That was my thinking, but im out of ideas as to what else it could be. Spoke to VX today who were no help.
    Berks
    Vehicle : Back Signum Design
    Engine : z32se
    Hi,
    Could someone tell me where is glow plug relay located on my Y30DT??
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. V6 Cdti glow plug relay
    By Critch in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 16:31
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
