Thread: changing the Vectra from RHD to LHD
    Jan 2010
    London
    Default changing the Vectra from RHD to LHD
    hi
    Just wondering if anyone has done this b4...I need to change my car from right hand drive to left hand drive as i have recently moved from the UK and i dont wanna sell the car as i love it:-)
    many thanks
    Administrator
    15 Post(s)
    You'll be talking big bucks to do that mate. Most probably not financially viable
    Regular Member Jezzy's Avatar
    S.E
    Very easy to do:
    Fit a "learner vehicle" pedal kit on the passenger side (brake pedal and clutch). Then remove the accelerator pedal from the existing drivers side and attach it to the new brake and clutch pedals. Cut into the wiring loom and run some wires from the accelerator pedal to the drive-by-wire throttle. Next, drill a 12mm hole in the dash on the passenger side (below the airbag), and obtain a 10" bicycle wheel (i.e. from a kids bike). Insert the end of the "axle" from the bike wheel into the 12mm hole you drilled. Take off the tyre from the bike wheel, and wrap around the bike wheel rim an inner tube from a 26" bike wheel. This will be too big, which is intentional, as you need to wrap the excess around the existing steering wheel. Thus, when you turn the 10" bike wheel, the car's steering wheel will rotate as well. Note however, that the car will now require more turns lock-to-lock, probably 4 instead of the previous 3. Always have a passenger sitting in what used to be the driver's seat, to operate the indicators and wipers etc.
    Full Member Penfold101's Avatar
    No-one remember Jeremy Clarkson's review of the Signum...? Variation on a theme an' all that...
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Very easy to do:
    Leicester
    Unfortunatly the Vectra C like many modern cars has a bespoke bulkhead for RHD amd LHD.
    You would need to change the entire bulkhead to do it. Older cars had bulkheads that were the same both sides. So you'll have to either stick with it or buy a left hooker.
  1. Help on changing deisal pump on vectra dti 2.0!!!!
    By ryanfoster in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2013, 17:00
  2. changing springs on vectra c sri
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 23:42
  3. Thinking of changing my vectra
    By molloy in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 14:46
  4. Thinking of changing the Vectra for a Zafira GSi
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 11:42
  5. Changing my Vectra!
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2008, 13:10
