Results 1 to 10 of 21
Thread: left foot rest
    N E Somerset
    Default left foot rest
    Does anyone know how to remove the plastic left foot rest? It appears to pull free apart from a bolt at the top right hand side which has a round head so am not sure how to undo it? Reason to remove is there appears to be some sort of black coloured chewing gum stuck to it which I would like to remove without damaging the plastic but it's awkward in situ.
    Btw, someone was asking about whether Signum mats fit Vectras in another thread. Well all four of mine have Signum RHD written on the label underneath and they all appear to fit perfectly even in the back footwells (mine's a Vectra btw).
    Jan 2006
    Skynet HQ EMEC#5
    The round headed 'bolt' is just a pin that is held in location by the plastic on the small end of the pin. I removed mine because the bottom part was loose, which I found was because the metal bracket had bent. Also removed so I could fit brushed stainless plate on top. The bottom part is held into the bracket by lugs on the footrest.
    HTH
    N E Somerset
    Thanks for the reply. So how do you remove the pin? Don't want to break anything.
    Nicking Ya Dinner.
    Why would you want to remove it?
    Apr 2006
    Bristol
    Ian can you get any more of the stainless plates. I would be interested in buying one off you. Have you got any pictures.
    Thankes
    Jan 2006
    Skynet HQ EMEC#5
    Sorry can't get any more plates, it was a one-off favour.
    I used a pair of pliers & screwdriver to prise it out, the plastic of the footrest bends in slightly and locates in a groove in the pin. All I did once the footrest was out was to squeeze the plastic together to make it tight again on pin.
    HTH
    N E Somerset
    Thanks Ian. I'm still not 100% clear how it works but will have a go tonight.
    N E Somerset
    Thanks Ian, your advice on how to remove it was spot on. Here's some pics of it off for anyone who is interested. Should be self explanitory.
    That's the carpet in the garage btw.
    N E Somerset
    N E Somerset
  1. Pedals And Foot Rest Finished
    By ScotsDragon in forum Styling
    Last Post: 16th May 2012, 13:55
  2. New Pedals & Foot Rest
    By ScotsDragon in forum Bodywork & Interior
    Last Post: 17th June 2010, 22:20
  3. Foot rest
    By grumpano in forum Insignia car chat
    Last Post: 13th May 2010, 16:43
can you get a left footrest for a corsa
removing vectra c footrest
