Thread: clicking/knocking noise
    Sep 2009
    newcastle
    Default clicking/knocking noise
    anyone had a clicking/knocking noise when turning steering from
    right to left sounds its coming from under the steering wheel.
    cheers
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    I had this sound, but did`t know what is it...
    I hear just in some times...not permanently....when the car is stops...and turn the wheels in left or right something sounds from wheel compartment...I think is sound like a spring...but not a broken spring...because mine is not broken but still sounds...I think is somewhere in the top of spring...somewhere there...(my opinion)...
    And sounds sometimes when driving with low speed (10 mph)and crossing some small bumps...(speed slower)...
    You where hear the noise ?Is the same like mine?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Broken spring... Mine didn't look broken when had the wheel off but i didn't notice the 2 inch missing from the bottom. made the same noise till changed...
    Southampton
    not sure if this is the same thing but i have a clicking sound when i move the steering wheel a inch to the right and a inch to the left but it only clicks once each way if i go right all thwe way back right a bit then right again it will nto clikc its like going left resets it
    it clicks as i turn it
    any thoughts guys ?
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    track rod ends are most likley to be shot. get some one to wiggle the steering wheel as you put you hand on the top of each track rod (no need to remove any road wheels just reach behind) and you will probably feel the ball joint clicking in and out, like iokarus says you wont feel it if you do all the way but you can feel it when you slightly move the wheel. hope this helps
    london
    or it could be strut bearings as they clunk and ping when they are shot.
    or could be everything thats been suggested- though I hope not lol
    Apr 2008
    leicester
    anti roll bar link worth a look get someone to turn the wheel wilst holding link bars mine was starting to sease up causing a clunk noise that you feel through the steering wheel replaced it probs gone away
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Drop links or springs I'd say.
    If the springs are not broken, (feel the end and if its jagged, they have broke), I'd say a new set of drop links is required.
    http://srx.uk.ebayrtm.com/clk?RtmClk...161378&pi=5197
    Jun 2011
    sheffield
    i have a 120cdti used as a taxi....i can guarantee you its the front strut top bearings...i have changed quite a few...well i just go to the breakers and pick up a used complete strut...quite easy to change...when you remove your old one feel the top bearing and i bet its lumpy when you turn it.....i beleive you can buy the top bearing/bushes new....good luck
  1. Check Strap Clicking/Knocking Door noise
    By msqualo in forum Bodywork & Interior
    Last Post: 1st June 2012, 13:02
  2. Clicking noise.?
    By telstar in forum Bodywork & Interior
    Last Post: 2nd August 2011, 09:00
  3. Clicking Noise
    By Lynchy in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2011, 02:33
