Results 1 to 10 of 17
Thread: Is Gearbox oil red?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default Is Gearbox oil red?
    It seems i have a smallish leak on my 1.9 DTI 150. I found it on the garage floor, it's around the size of a piece of A4 paper (although not as square ). It was red-ish in colour. I've wiped it up so i can see how much it's dropping.
    The DMF and clutch was replaced in January, so i'm thinking it might have something to do with that.
    Any thoughts guys?
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Yeah gear oil is red, maybe drivesheft oil seal leaking..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Some gearbox oils are red yes, but so is the coolant
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Does the coolant feel oily?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Yes.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Any difference in taste?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Pink is long life and green, blue, yellow are not lol
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Coolant tends to be more like a day-glo orangey-pink to make leaks easier to spot...also your header tank level will be low if you have a coolant leak.
    Gear oil tends to be red to reddy-brown
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    coolant can be whatever colour the antifreeze is, depends on the manufacturer.
    its common to have auto gearboxes & power steering systems used the same type of fluid in each system, but not sure about manuals. but theyre usually red.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Well, i spent 2 hours this afternoon investigation (most of it removing/refitting under-tray I'm gonna love it when the time comed for an oil and filter change )
    I took some pictures of what i found. Looks to me to be the dirveshaft seal leaking. Was alanv6 right? If so, is it a big job/expensive?
    Like i mentioned in the first post, i had the DMF and Clutch replaced in January, might the seal have been damaged when they were changed? If it's not an expensive fix, i might not bother ringing them up incase they either deny that it might be, or they fix it and damage something else.
    View from below, front of car at bottom of picture. A nice few drips ready to stain he drive. Looks a little like monkey's blood.
    Closer inspection finds where it's coming from. I've added a little red arrow
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
red gearbox.oil vectra
