Thread: Help please!
    Regular Member TonyJames's Avatar
    Sep 2009
    northants
    Default Help please!
    Just fitted my new kenwood single din stereo half canbus 04 plate signum
    Engine on: it works ok and when driving it seems ok, but when stationery engine still on if i turn the steering wheel its cuts in and out as if the powers not getting through.If i rev the engine and turn the wheel its works ok though.
    Then engine off and ignition turned to position 1 it stays on for 10 to 20 seconds then starts to cut in and out again as if theres a power problem.
    Oh wise ones please help
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    EHPS taking all the power matey at standstill think it can drain up to 90amps
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by TonyJames View Post
    Is yours a DTi mate? I have this exact same problem with my Kenwood, not had a chance to fix it yet though. I believe a feed from the 12v socket would solve the problem with the engine running but not sure about when its off
    Sep 2009
    northants
    Mines 2.0T,the old cdr 2005 worked fine so whats wrong with the new kenwood i dont know
    i've been reading some old threads about swapping the permanent and switched live over? maybe this will work anyone know? i thought it would be a straight swap over otherwise i would have paid someone who knows what there doing
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No swapping the wires over only stops the radio losing its memory,and lets it be controlled by a switched live, I'll have a look at mine over the weekend and report back
    Sep 2009
    northants
    Thanks John
