Results 1 to 10 of 26
Thread: just fitted new springs
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default just fitted new springs
    ive just fitted new springs -35mm Apex springs
    i was thinking that it has went a bit lower than i thought it would on the rear is this normal on standard springs
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    i dont know mate but looking at it, looks too low at rear in my opinion though....
    Trim : SRI
    Mileage : 46000
    i myself dont like it that low and the missus hates it but thats all the funds i could afford for the springs
    Worcs/Staffs/Westmids (ish)
    Mine dropped by probably 40-45mm on the rear with the Eibach Pro 30mm springs.... Your is probably 5-10mm lower than mine all round.
    As standard they do seem to sit high at the back.
    I think it the Vecc was just designed to carry a lot of weight in the boot.
    Jul 2009
    Newcastle
    Quote Originally Posted by rickeys16v View Post
    now this might sound stupid but you havent got the spring the wrong way round by any chance???
    Trim : SRI
    Mileage : 46000
    the back springs were not the same shape as the ones that came off the new ones were small at the bottom and got larger at the top ( hope that makes sence) they were also about 1 1/2 - 2 inches shorter
    Trim : SRI
    Mileage : 46000
    just looked at the box they came in and it says Calibra on the box but its the same part number as a vectra c (60-8210)
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    For a 35mm drop (or 20mm in terms of an SRi) that is very low indeed, could be wrong springs (spring weights) but I think the back ones for all Vecs are the same (excl estate) I'm sure someone would correct me if I'm wrong.
    Some pics of another Vec with Apex springs here.. http://www.vectra-c.com/forum/showpo...82&postcount=4
    ..and another... http://www.vectra-c.com/forum/showpo...59&postcount=1
    Regular Member i5aces's Avatar
    andover
    what engine do you have mate as there the springs i just got (same part number) and my box says
    vectra 01>
    engine 6 cyl
    weight 1000>
    that should be right correct for my v6 but might not be for your car
    p.s i havn't fitted mine yet hoping to at the weekend so could post up pics and compare
    Lancashire
    Trim : XP1
    Mileage : 66000
    The V6/DTi/CDTi springs are the same, well are for other brands.
  1. fitted springs
    By gazthebigyin in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2012, 23:09
  2. VXR springs fitted...
    By stampede in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 23:02
  3. My springs are fitted
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 16:54
  4. fitted springs
    By neverlandandy in forum Styling
    Last Post: 7th July 2009, 00:54
  5. going to get my springs fitted
    By tightlines in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2009, 01:02
