Thread: Yellow light under the fuel guage
    London
    Default Yellow light under the fuel guage
    Hi Everyone,
    please help yesterday when i was driving home I saw my yellow light had come on!!
    Its under the fuel guage and looks like a engine block.
    I Looked at the manual(p102/194) it says emissions ???
    Please help!! Asked the Stealers to check it they said £55 for half an hour.
    I did service the car last weekend but havent changed the spark plugs, if that helps.
    How do I find out what the problems is and cost?
    How do i reset the light?
    Help!!
    Jav
    8 Post(s)
    Quote Originally Posted by Nokia1 View Post
    See if you can do the pedal trick - mentioned in the how2 section.
    Once the fault has been rectified, the light should go out of its own accord.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If it is the engine warning lamp, it means that there is a problem / fault with your car. You need to get the fault read, but don't need to go to VX for this to be done. Most generic fault readers will be able to retrieve it, and without the fault code it is almost impossible to know what the problem is
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Invest in a fault code reader, i have just bought a U480 off ebay for £20 new, will give you any fault codes registered and you can clear them as well. Comes with a book thats full of fault codes and description.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as H says ,the U480 works spot on
  1. How long does your fuel guage take to show
    By The Flying Banana in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2011, 22:21
  2. How accurate is the range and fuel guage?
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2011, 08:34
  3. Fuel Guage - Cold Weather?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 13:52
  4. Faulty Fuel Guage?
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 12:12
  5. Fuel level guage
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2006, 12:43
