Originally Posted by
Chocki
I'll try and get some pics this weekend, but basically, I cut a bit of stainless plate 40mm wide and left it 80mm long while trying this out, but 40mm square or round will do.
Remove the egr and with a bit of easy gasket, bolt the plate between the bottom (inlet) of the egr and the pipe going to the exhaust. You want this plate to be fairly thin.
Then bolt the egr back onto the inlet manifold, you may want to put a little gasket sealant or a new gasket on.
When you start the car, you will get the spanner light come on, this may come on and off as you drive the car but will become the EML when you next restart the car.
But the car is not in anyway hindered by this, no limp home mode or anything amis that I can see, diagnose etc.
Code reader shows p0400 EGR gas flow and nothing else.
So I'm going to leave it for now.
