Thread: 2.2DTi - Cold start fail at -1C
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Talking 2.2DTi - Cold start fail at -1C
    Mum wanted me to start her car up and let it run for a bit. Well, here's the result of bad glow plugs coupled with a near-dead battery.
    Attempt 1 - Fail
    http://www.shrani.si/?3G/ad/213toKHV/10032010005.mp4
    Attempt 2 - Succes...just
    http://www.shrani.si/?36/9K/1GXAjgiP/10032010006.mp4
    Jan 2010
    Liverpool
    Had it on the Mrs' 2.2DTi. Took alot of cranking over with the gas pedal to the floor to get it going.
    Regular Member david.aka.judas's Avatar
    Suffolk
    time for a service....lol
    Sounds more like a steam engine...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Just changed the oil and filters, but it still needs a new thermostat and glowplugs lol
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Careful when removing the glow plugs,they are known to snap at the hex part and then they are nearly impossible to remove without damaging the threads.
    I've heard people mention,soaking the glow plugs in alloy wheel cleaner the night before,to help break down the seal that has been made between the alloy head and the steel glow plugs.
    I went to change them on a hot engine,as recommended by a vauxhall mechanic,one snapped in place,and i had to have the hole heli-coiled
    On the next dti i went to change the glow plugs on,i did them when the engine was cold,they all came out fine,i sprayed them with my cheaper version of wd40 before trying to undo them,i moved them just a fraction at a time,undoing them and doing them back up and kept spraying them before doing them back up each time.
  1. Z30DT fail to start
    By satwien in forum Y & Z30DT Specific
    Last Post: 5th January 2013, 15:26
  2. Power Steering Fail in Cold
    By MrAnderson in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:04
  3. 2.2dti 'semi' cold start prob (AGAIN)
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 11:44
  4. 2.2dti 'semi' cold start probs
    Last Post: 22nd January 2009, 11:57
  5. 01 Vec B 2.2dti cold start no revs!
    By tommoturbo in forum Engine & Drivetrain
    Last Post: 31st January 2008, 05:41
