Results 1 to 10 of 21
Thread: Retro fitting a CD70 upgrade from CD30
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default Retro fitting a CD70 upgrade from CD30
    I am buying a CD70 but it has no cables with the sale
    what are my chances of anyone havin the cables spare... none probably .. but dont ask and u dont get told NO
    anyway ... if anyone can advise .... if i can get them or if i am able to obtain them from GM ??
    What cables do i need ?? ... appart from the sat nav aerial
    Thank you
    Tim
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you should only need the rgb cable (only available from vx - See pic below) that connects the headunit to the screen which allows the maps to be displayed, the gps antennae (blue connection) as you are probably aware can be substituted with a Fakra gps antennae from ebay for about a tenner... the cable that connects the headunit to the car is the same so is the connection for the GID and CID screens...
    RGB cable
    Back of CD70
    Fakra gps antennae (I have a spare one of these if your interested)
    shropshire
    Quote Originally Posted by Caveman_nige View Post
    Ur a star ... de-stressed me in one message. Ill order the RGB cable from GM then... few
    And iv got a spare sat nav aerial from my old tomtom.. i guess that will fit ?
    and that the power supply is the same .. Buzzin
    If i can now pick this CD70 up tomorrow im laughing.. been offered one for £250
    Thank you so much
    Tim
    P>S .. how did u get the Aerial cable down the back of the dash ?
    Jun 2009
    South Coast
    what screen are you attaching it to... from what i remember the cd70 does not need to be 'divorced' from car by tech2 neither does the CD30 but the screens and headunits are 'married' by tech2.. therefore in my understanding you will need the screen that was connected to the headunit if it or you will need to have somebody with a tech2 machine 'divorce' your CD30 from its GID screen and then 'marry' your CD70 to that screen...
    I could be wrong on this but i would seek clarification before you part with your dosh..
    btw i bought my cd70 of the bay with the rgb cable and the colour CID screen with its plastic surround for just under £300.... be careful not to spend too much as sometimes they can be priced to high..
    shropshire
    The screen is coming with it and so is already linked. Ill remove my old screen and CD30 and flog em
    Jun 2009
    South Coast
    cool.. then its a straight forward plug and play, when you get the rgb cable you can then play with the navi function... when i took out my CD30 i found a proper vx gps antennae cable already behind it just waiting for a CD70... pop yours out and have a look you may get a nice surprise..
    hull
    Quote Originally Posted by Steven T Davies-Moss View Post
    what screen does your cd30 have with it pal? gid?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It is obvious, but the RGB cable is only needed for colour screen (CID)...not needed for GID.
    If you don't already have GID, then you may need to link a couple of pins in the 32 pin connector plug.
    The GID requires 2 x red (+12 volts) and 2 x brown (chassis) for it to work fully.
    If you have TID or BID, then they sometimes only have one of each. (not a major task to sort out).
    TomTom aerial block comes with the wrong connector...
    I put a fakra plug on a Tom Tom aerial, and it works fine in my cavalier..I use it daily when I go out on "visits".
    Fitting the aerial block is tricky to say the least...I don't have a mid-dash speaker nor a sun-sensor in the wife's vectra, and it was a very tight squeeze to get ebay sourced block between the air trunking behind the display, to where it came out under the mid-speaker grill in the dash.
    If you have this speaker or a sun-sensor, then you will need to find an alternative location.
    shropshire
    Quote Originally Posted by frasedeb View Post
    Mine's the small screen wiv two buttons underneath it
    shropshire
    So whats this TID, BID & GID stand for ??
    i know they are screens but means nothin to me yet
    the one i currently have is small wiv 2 buttons under the screen
    And the one im getting i know is a CID full colour full size screen
    will i need to adjust + / - wires as below ?
  1. Upgrade CD30 to CD70 or go for aftermarket?
    By saggybelly in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 19:51
  2. Retro fitting cd70 nav
    By family guy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2010, 21:21
  3. fitting cd70 into cd30 place
    By bigpaw35 in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2009, 15:19
cd70 rgb cable
cd70 pins
cd70 navi gps
upgrade from cd30 to cd70
gm opel cd70l
opel cd 70
cd70 back
cd drive for cd70
vectra cd30 to cd70
upgrade cd30 to cd70
