Results 1 to 3 of 3
Thread: Front brake screeching!
    Jan 2010
    Liverpool
    Default Front brake screeching!
    I swapped my front discs and pads and the drivers side ended up screeching something terrible. Even more so when turning left, lol.
    I whipped the wheel off tonight and it turned out the bottom section of the dust shield was touching the disc.
    The inside of the old disc was worn more than the other faces of the discs. I guess this could be the reason.
    All sorted now, anyways.
    Just thought I'd post my findings incase anyone else is having similar problems.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep I had this problem. It only did it when the discs heated up
    Jan 2010
    Liverpool
    Yeah, it was worse when the disc heated up.
  2. screeching when starting ??
    By mccluskey119 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 23:52
  3. Pads are screeching! Please, suggest new
    By alexey88 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2010, 22:52
  4. Screeching sounds when cold?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 12:32
  5. Knocking and screeching
    By Fulgrim in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 17:42
https:www.vectra-c.comforumshowthread.php104869-Front-brake-screeching!
