Results 1 to 10 of 23
Thread: Twanging suspension when turning
    Jan 2010
    Liverpool
    Default Twanging suspension when turning
    My drivers front spring twangs when turning. This started after I fitted 45mm lowering springs with SRi shocks.
    I thought it was going to be a case of fitting the sleeve to the bottom of the spring, but it turns out that the top bearing is goosed.
    Can anyone advise the cheapest place to buy a replacement, please?
    Also, is there a specific way around it fits? It didn't look like it when I swapped them.
    Regular Member samngeorge1985's Avatar
    lanark scotland
    strut top bearings are a dealer only part you can only get them from dealers
    Jan 2010
    Liverpool
    They're around £45 from dealers aren't they?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by samngeorge1985 View Post
    Who told ya that?
    www.eurocarparts.com
    Jan 2010
    Liverpool
    This is the correct part I take it.
    http://www.eurocarparts.com/ecp/c/Va...sion-Mountings
    Jan 2010
    Liverpool
    Ordered a new one from dealers today. £19.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    also ck that its not the torque screws holding the top mount hitting the springs
    just undo one at a time and put a couple of washers under them .
    might save you changing the top bearings
    Jan 2010
    Liverpool
    Can that really cause the problem?
    Its strange, as it only happened after I lowered the car.
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by Mogsy007 View Post
    yes it most certainly can ....saw proof of it Sunday
    Jan 2010
    Liverpool
    Geez. When the steering wheel was turned I watched the bearing and it looked as if it was trying to rip itself apart. I could see the bearings inside it.
    Ahh well. If its got itself into that state I'll fit the new one anyways.
  1. Replies: 4
    Last Post: 25th June 2012, 22:40
  2. 'Twanging' noise from front right??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 21:00
  3. twanging front springs
    By DARREN R in forum Handling & Braking
    Last Post: 9th July 2009, 11:12
  4. Twanging Noise
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2009, 14:43
  5. Handbrake twanging noise
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2009, 09:44
