Results 1 to 10 of 19
Thread: Engine/Emissions warning light
    Aug 2009
    South Yorkshire
    Default Engine/Emissions warning light
    Apologies if this has been covered before!
    The engine warning/emissions light has reared it's ugly head on my 56 plate Vectra today. The car is running perfectly, no loss of power at all, no black smoke and drives as normal. There is plenty of power through the rev range too. It hasn't been for a long run recently due to the weather/work etc. Could this be the reason?
    I have called into the dealers to get advice, and they have said if it runs ok, it's ok to use. Any problems and call back in.
    Being as it's running just fine is there a way to reset the light to see if it comes back on again?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    only with a code reader bud
    Aug 2009
    South Yorkshire
    Cheers Chris. I thought that may be the case, I'm just being a tight arse as usual! I'll monitor it over the next week or so until I can get it booked in for checking,
    Are you VXR Enough
    13 Post(s)
    there must be somone in your neck of the woods with a code reader fella??
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You might be able to get rid of it by disconnecting the battery for 30mins or so.
    Quote Originally Posted by MultiDropper View Post
    So, have both the engine warning & emmission lights come on;
    or is it just the engine electronics fault light? (pic of car/spanner)
    or the emmissions light? (pic of engine)
    Aug 2009
    South Yorkshire
    Sorry it's just the pic of an engine (Orange) I wasn't really sure what it was hence why I said engine/emissions.
    Well, the light is still burning away in my dash. However the car runs a LOT better since it's been on! By running better I mean it pulls like the proverbial train. So, whatever it is that's gone has made a huge improvement to the power of the engine. It always felt a little flat before until the turbo kicked in, not anymore!
    I really should get it done asap though.....
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Best thing is to get a code reader, apparently argos sell one for 40 something pounds, it'll cost you twice this much to go to a dealer!.
    I'ts something that will most likely save you a lot more than the cost of the reader in the long run as it will work on many cars and lets face it, ALL new cars so will last you a long time indeed.
    Code readers used to be out of reach of most people, but these days with more and more reliance on electronics in cars, they are very necessary.
    With the code and this forum, I'm sure the reader would probably pay for itself the first time you used it and it's not as if it's never going to be used again since it will work on this car and unless you buy an older car, it will work on your next car as well....
    Hope I've convinced you to buy a code reader...
    BTW, apparently there is a way on Vec's to read the code without needing a code reader.
    Jul 2006
    Wolverhampton
    Yay!, it's gone up!!! £70
    At this price you can get an Autel Maxiscan 509 which gives you a lot more diagnostic information, available from E-Bay.
    Sorry for misleading you on price, there are cheaper code readers like this one:
    http://cgi.ebay.co.uk/Autel-MaxiScan...-/190365466286
    Aug 2009
    South Yorkshire
    Thanks for that Chocki. I have considered a code reader purchase. I just haven't got around to it. Even the £70 is cheap though considering the use it could end up getting?
    As I have mentioned though, the car is running brilliantly, better than ever before in fact...so whatever caused the light to show in the first place, and is now not working is restricting the engine power? Who knows...
    I'll look into a code reader, and thanks for the advice.
  1. Emissions warning light on
    By peterb11 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 17:03
  2. Emissions Warning Light
    By fifesri in forum Engine & Drivetrain
    Last Post: 14th September 2010, 20:58
  3. Emissions Warning Light
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 19:23
  4. Emissions warning light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 21:19
  5. Engine cutting out!! Exhaust emissions warning light! Help!
    By jde1 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2009, 23:39
vauxhall vectra emissions warning light
vectra c emissions warning light
vauxhall vectra exhaust emission warning light
vectra c emissions warning light reset
vectra exhaust gases warning lightvectra emission warning lightvauxhall vectra c emissions warning lightvauxhall vectra emissions lightvauxhall vectra exhaust gases warning lightvectra emissions warning light20 11 insignia emissions light turn offreset engine dash light on vauxhall vectraengine warning light vauxhall vectraexhaust gases light vauxhall vectravauxhall vectra c exhaust emissions lightvauxhall meriva exhaust emission warning lightvauxhall insignia emissions lightemissions light vectraengine warning light vectravectra c emissions lightemissions light on a vectra cengine lights on a vectraExhaust control light has appeared on my vectra c with loss of powervauxhall vectra warning lightsvectra c warning lights
