Thread: Fault code query
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default Fault code query
    The signum has just gone through her mot today , passed without any issues , but she also had a service while she was there one of the issues that came up was a fault code of po606 which according to the fault code chart transfers too pcm processor fault other fault,s that also arose were po100 maf sensor po638 boost sensor fault and po338 glow plug sensor fault .
    what i am after is has anyone come across this po606 fault before and does anyone know what it relates to, or is it purely connected to one of the other fault codes raised
    WGAF#5
    pcm = powertrain control module ??
    i wonder if the other faults are generating sperious faults on the PCM<
    Engine : 2.0DTi
    Mileage : 73350
    bump, bump.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    P0606 Control Unit Internal Communication Error
    whichever control unit that belong too
    Regular Member Jezzy's Avatar
    S.E
    Might be a symptom of a dodgy alternator.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They might just be glitches that are no longer present. I would try resetting the ECU and seeing if they return.
    Jul 2013
    Wakefield, West Yorkshire
    Vehicle : vauxhall
    Trim : vectra
    Engine : 2.0
    Quote Originally Posted by bobssignum View Post
    Hi Bobssignum, Did you manage to sort the P0606 code out as i have the same problem with the spanner light coming on but the battery light comes on as well. It runs fine but when i turn the engine off it won't start as it clicks as if its draining all the power and acts like the starter motor is stuck but it isn't?
    Any help would be most grateful
  1. Fault code reader query - 2002 2.2 DTi
    By James24 in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 15:47
  2. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  3. Fault code
    By welshboy in forum Engine & Drivetrain
    Last Post: 27th September 2011, 17:44
  4. Fault code readers, EML and glow plug query
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 19:44
  5. Fault code ID
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 21st March 2008, 04:24
