Thread: Tapping noise
    New Member james tierney's Avatar
    Aug 2009
    doncaster
    Default Tapping noise
    hi all . i have a 1.9 cdti 150 vectra sri and there is a tapping noise coming from around the vacuum pump or injector 4 area . just wondering if its normal . not had car long so not sure if it has always been there, want to find out before i take in to garage under warranty . Any help would be appreciated cheers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Water pumps, belt tensioners can cause tapping noises, even a failing alternator can cause the noises too, if you're not sure, best to get it checked out - they don't do it normally though bud.
    Aug 2009
    doncaster
    cheers for the reply mate but the noise is at other end of the engine near oil filler cap
    Aug 2009
    doncaster
    just found out its only doing it when engine is warm. dropped it off at dealers to check it out and replace rear springs .
    will post results when i find out what it is
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    is it a fast, light tapping noise that changes speed with the engine speed? if so, its most likely one of the hydraulic tappets, solutions would be to replace all of them, change the oil after using a flushing additive, or turn the stereo up, but im no expert!
    now someones gonna tell me that the diesel engines have push rods lol
    Aug 2009
    doncaster
    well acording to the dealer its a normal noise for a diesel engine , im not convinced going to get a second opinion
  1. Z20NET tapping noise
    By Kev_A in forum Engine & Drivetrain
    Last Post: 3rd October 2012, 14:12
  2. tapping noise
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 11:50
  3. Tapping Noise
    By jay146 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 15:28
  4. tapping noise behind glove box
    By chrishornby in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2007, 22:51
  5. Tapping noise at 60-70 mph.
    By Andrew Hambridge in forum Petrol Engine related
    Last Post: 31st July 2007, 15:00
1.9 cdti vacuum pump tapping
insignia vacuum pump noise
