Results 1 to 10 of 17
Thread: signum temperature gauge
    St Helens
    Default signum temperature gauge
    Just picked my signum up tonight everything seems to work fine but temperature gauge didnt move any ideas.Cheers Paul
    Did the heater work?
    Did the pipe from the engine back to the radiator feel hot?
    St Helens
    Heater was great not checked pipe yet.Thanks
    North of Watford Gap
    Angry
    Quote Originally Posted by paul700r View Post
    What engine do you have in your Signum? I have seen on previous threads that diesels take longer to warm up than petrols.
    You don't say how long your journey was but you obviously had the heater on. I had the same concern with my Signum 3.0 CDTi when I test drove it and it was only at the end that I found that the gauge worked. It still takes much longer to reach working temperature than I was used to with my previous petrol Astras. I drive around 17 miles to work and it typically takes 5 or 6 miles of ordinary driving before my temperature gauge starts to move and a couple more miles before it reaches its normal 85 degrees. In winter, it sometimes doesn't warm up completely before I reach work if I have the heater on fully!
    I had the thermostat replaced under warranty but it hasn't changed things to any great degree.
    Hope the solution is as simple as mine
    St Helens
    Hi its the 1.9 cdti 150 did a 70 mile trip after collecting car, heater worked fine will have a check today hopefully something simple
    Leicester
    Go into test mode on the dash display and you will get a digital temperature gauge, this is more accurate than the gauge itself.
    It'll give you an idea as to how out of calibration the gauge is. The gauge can then be re-calibrated using tech 2.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    how do you go into test mode mav
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    when we had the cold snap my temp barely moved. now the weathers warmed up as bit it rises after bout 10-20mins. id say its nothing to worry about. as long as the heaters are blowing hot its fine
    If it's the CD70, then press and hold down the Settings button until "test mode on" is displayed, then keep pressing the BC button until the relevent option is displayed.
    Are you VXR Enough
    13 Post(s)
    mine has a cd30 so probably wont do that
  1. temperature gauge
    By kewley in forum Engine & Drivetrain
    Last Post: 16th July 2011, 16:06
  2. temperature gauge
    By chrisknights in forum Bodywork & Interior
    Last Post: 16th February 2011, 23:42
  3. temperature gauge
    By kalim in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2009, 22:05
  4. Temperature Gauge Help
    By Oscar Ding Ding in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 21:51
  5. Temperature Gauge
    By domino in forum Engine & Drivetrain
    Last Post: 23rd July 2007, 10:39
