Thread: Factory Fit Bluetooth Fault
    Northants
    Default Factory Fit Bluetooth Fault
    I've got an 06 facelift vectra elite with factory fitted bluetooth phone kit which has developed a fault.
    It worked fine until my alternator died, and sat for a couple of weeks with no battery connected.
    I noticed when I dropped the car off at the garage for repair that when I took the key out of the ignition, the colour screen did not turn off, and since then the phone kit has not worked.
    Initially the phone icon was missing from the header section of the screen, it still had 4 boxes, but the phone icon had gone. Because the screen would not turn off with the ignition, I disconnected the battery overnight to get it to switch off. Next time I connected the battery, the phone icon was back, but when I tried to search for devices it would do nothing.
    Over a couple of days I realised that sometimes it would show no phone kit present, sometimes it would detect the kit, but on the phone screen would only show the signal bars and no operator name, and sometimes it would say 'No Phone' and would not search for one.
    Rather than drop the battery off everytime, I realised after I switched off the ignition I could pull a fuse which fed the screen, and reset it that way.
    Ultimately though, I have removed the bluetooth module and since then the screen has gone off fine with the ignition, so it does seem to me to be a bluetooth module problem.
    (I did also try reinstalling just to see if it was a loose connection, but the fault came straight back.)
    Has anyone out there come across this problem before, if so what was the fix?
    Cheers,
    Phill
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Not come across that problem before but by the tests you have done it very much points like its that unit at fault doesnt it?
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    it seems to me that the uhp module needs a boot,just disconnect the
    plug from thre uhp unit for few mins then re fit it and then insert a cross in
    the uhp visible box in the bluetooth menu then pair ya phone up,if this
    doesnt work then id put it down to either a faulty uhp module or it will
    need the latest software update.
    let me know if this works and how u get on
    Oct 2006
    Wellingborough
    Hi Phill,
    That is Andy who i mentioned before! Trying to reflash the module sounds like a good idea, if it can't be flashed the module is definitely faulty, and post flash it'll either work (which would be nice!) or it won't and is therefore definitely faulty. I'm sure Andy could then sort you a new module for a sensible price...
  1. UHP Factory Bluetooth
    By millard2004 in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 22:02
  2. anyone with factory bluetooth???
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2010, 14:06
  3. Factory Bluetooth?
    By muad_dib77 in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 21:21
  4. Factory Bluetooth
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 00:09
