Thread: Strange noise from engine compartiment...?!?!?!?
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Default Strange noise from engine compartiment...?!?!?!?
    Hy.
    For couple days i hear an strange noise from my engine when i start it...(1.9 cdti 150).
    In the morning I start the engine and for 5-8 seconds all is OK....but then starting to clinking from the auxiliary belt area...(not the timing belt area).....
    So I`m asking you if some had this problem...and how to fix it?
    The belt has been changed 10k miles ago, so the belt is ok i think...
    Can be the one of the pulleys?Witch one is more destructible???
    Is this a common fault on this engine??How many is the cost to repair/change??
    And I don`t have the shield under engine (protector)....can i find one Second Hand and cheap in UK but with shipping to Romania?How much it costs?
    Thanks again all...
    Cheers.
    Regular Member OSSY's Avatar
    Apr 2009
    Hope you get sorted... Not sure on that one, but the shield shouldn't be that expensive, £40? I'm guessing...
    Jul 2009
    Bistrita
    I think is my crankshaft pulley gone (or just starts)....
    Where I can find a cheap and good crankshaft pulley?
    New or Second Hand....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I have a similar problem but describe mine as more of a slight squeaking, I'm removing a few parts tomorrow to find out what it is.
    Try turning on the air conditioning - my pump rattles when it's not in use (climate control in ECO mode) but it vanishes when you turn the pump on. Might be worth a shot...
    Jul 2009
    Bistrita
    Today I was at a friend to the garage and I got lift car and got off auxiliary belt .... then I spin all the rolls by hand, but nothing seemed suspicious...the crankshaft roller could not spin as it spins only when the engine is started .... I will try to start the engine tomorrow without auxiliary belt ... would be something wrong with that?
    I think if I start the engine without auxiliary belt and the knocking is still there, can be the crankshaft pulley of the timing belt...not the auxiliary belt?Or i`m wrong with that?
    If my crankshaft roller is dead, does anyone know how much it cost?
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by Maxim007 View Post
    New pully from Vauxhall is around £150
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    think you can get them for around £100 from ebay. i took the air filter box off and dropped the whole bottom pan as well, its only a slight intermittent squeak and sounds like a dry ball bearing, I'm doing a midlands to west yorks round trip sat so hopefully it will be OK!, i wont be able to do a test by removing the aux belt till next week.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    http://cgi.ebay.co.uk/CRANKSHAFT-PUL...item4ced0f8ad2
    Do you really want to save a whole 50 quid by buying a part that you have no idea where it's been made, who by, and to what tolerances...? Jsut the the VX one, it's not that much more expensive you know where where it's come from...
  1. 1.9 cdti engine strange noise
    By n1ks0n in forum Engine & Drivetrain
    Last Post: 10th January 2013, 00:49
  2. Strange noise from offside engine 2.0T
    By Steven in forum Engine & Drivetrain
    Last Post: 16th December 2012, 10:44
  3. Strange Engine Noise
    By CraigoT in forum Engine & Drivetrain
    Last Post: 13th November 2011, 18:08
  4. strange noise from engine cdti 150
    By kamar in forum Engine & Drivetrain
    Last Post: 12th April 2010, 17:16
  5. Strange engine noise
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 18:01
