Thread: Urgent Help Needed...
    Regular Member OSSY's Avatar
    Apr 2009
    Default Urgent Help Needed...
    The only reason why I say it's urgent is because I need to drive the car this evening...
    I've got issues with my steering - should this nut have a bolt the other side of the joint? Is located at the bottom of the steering column... Many thanks...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    what issues do you have bud
    Apr 2009
    Wobble in the front wheels when slowing down mainly... But all tyre pressures are fine, tracking, balance too... Drop links might need a change but my main worry is that i think there should be a nut at the other end of the bolt (see pic) at the bottom of the steering column??? What you think?
    Are you VXR Enough
    13 Post(s)
    it dosnt have a nut fella its just a bolt
    Apr 2009
    Awesome... You sure about that? Sorry to question... Back to drawing board then... Thanks very though...
    Full Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    You sure its not slightly warped discs OSSY ?
    Are you VXR Enough
    13 Post(s)
    well mine is the same as yours fella
    Apr 2009
    Could be worpped discs...
    Thanks for the advice...
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    My pinch bolt came loose once, had play in steering and wobble at speed !
    Apr 2009
    Sorry what is the pinch bolt
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
