Results 1 to 10 of 11
Thread: spanner light then engine management light
    grimsby
    Default spanner light then engine management light
    Hi guys had the old spanner light flag up on my 1.9cdti 150 stayed on for the 10 minsi drove it next time i started engine no spanner light just engine management light. car still runs as powerfull as ever and full con is still great any ideas.due a service in a month would you wait till then to get it fixed,i do about 500 miles a month 50% motorway.any help would be great
    cheers
    learoy69
    Regular Member VectraGezza2010's Avatar
    Jan 2010
    Anstruther
    My engine management light came on but the can still had all its power and that. the problem was the EGR valve was stuck so i got a new one i also cleaned the Boost sensor as well. hope this helps
    grimsby
    wonder if i show take the egr valve off and give it another clean
    grimsby
    forgot to mention mine is an estate model so will have the dpf filter if that makes any difference to the outcome
    grimsby
    bump
    11 Post(s)
    Quote Originally Posted by learoy69 View Post
    The spanner light is the engine management light. The other light is the emmissions fault light.
    Sounds like you need the fault code(s) reading out which takes away all the guesswork.
    grimsby
    hi all got a code reader off ebay gives me code p0400
    in the book it says grneric fault egr flow malfunction
    is this corect and how do i fix it chheers
    West
    Try cleaning the egr... there's a howto on here.
    grimsby
    did that about 9 months ago will give it another go
    grimsby
    found how to clean egr on on dti is it the same for cdti 150
    cheers
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  4. 'Spanner' engine management light on 2.0Dti
    By Bigdrinks in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:50
  5. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
vauxhall astra cdti 150 spanner light and engine management light
