Thread: cleaning insignia washer jets?....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default cleaning insignia washer jets?....
    my insignia jets must be blocked up as there is just a dribble of water coming out of them , had the pump off the washer bottle today and cleaned out the filter but its still made no difference, anybody got any cleaning tips for the jets????
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    The jets could be fine, I had the same problem with mine and it turned out to be the rubber filter on the pump in the washer bottle, take it out, clean it, and then you should be back to full power.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    you could try getting a bit of plastic tubing (old washer pipe)
    & blowing down it
    or buy a shringe from a chemist (about 50p) & fill with water & try to force the muck out
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by R13hard View Post
    already cleaned the filter mate as said in the opening thread, its like the jets are blocked, when i had the normal one's in then, when they got blocked a small bit of wire did the trick,but it wont go in the hole on the insignia ones
  1. Insignia Washer Jets
    By 11mallard in forum General Chat
    Last Post: 28th May 2012, 19:55
  2. Insignia Washer Jets
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2011, 20:42
  3. Insignia Washer Jets
    By simmo3187 in forum Styling
    Last Post: 28th February 2011, 20:19
blocked washer jets insignia
insignia washer jets blocked
