Results 1 to 10 of 25
Thread: Egr / swirl valve headache
    salisbury
    Default Egr / swirl valve headache
    Egr / swirl valve headache!!
    SIGNUM 2006 1.9CDTI 150PS AUTO.
    Can someone help with this, have had all the usual probs as listed below;
    poor power under 2500 rpm
    no spanner light
    swirl valve arm attached
    lumpy tickover until i rev it a bit.
    cleaned EGR valve and cleared 2 EGR holes in inlet manifold, boost sensor.
    Power restored for about 2 days then back to no power. I have checked the valve and sensor and all is clear, checked the swirl valve arm and that is still on although very loose and i have noticed that when the engine is running the fourth swirl valve top is slightly moving within the arm cup.
    back to square one help.
    cheers doug
    Bristol
    Vehicle : CDTI 150
    DOug, have you done the 'full' clean of the EGR, i.e. drifted out the solenoid and cleaned it?
    Dartford
    Do these faults only affect the 16v 150 engine?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Check the injector plug connections.
    Oct 2009
    southport
    has anyone ever challenged vauxhall in the small claim court for the whole EGR/swirl valve/manifold fiasco, I think I will chance the 40 or 50 quid it costs and see what happens, I think I have a case under the 'not fit for purpose' rule
    CHESHIRE
    dougb it sounds very similar to the problem i had ,no power under 2500 revs rough tick over but no warning lights, done a full egr clean power back for a few days power starts to fade away again, another egr clean power back again and so on .
    anyhow done a bit of research on this web site and came to the conclusion you can clean the egr valve dozens of times ,but the problem will always come back .In short new egr valve problem gone...
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    vx told me last week! if its upto 5yrs old with full service history then they will do something but otherwise not!.
    salisbury
    Is the full service history a vx history or just the book stamped at the correct intervals, which mine has but only first was vx. Just incase
    CHESHIRE
    guys any idears please ,im having the exact same promlems as dougb no power under 2500 revs ,clean egr valve power back for a few days then power fades away egr back off and cleaned power comes back .
    anyhow to cut a long story short bought a brand new updated egr valve from vauxhall warehouse car runs fantastic for a couple of days ,today its back to the ald no power under 2500 revs again . Guys starting to pull my hair out here any idears PLEASE ...
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    Quote Originally Posted by dave r View Post
    give the boost sensor a good clean using carb cleaner i have just had a new egr valve put on last week and it ran so much better, on wednesday i cleaned the boost sensor and it has made even more of an improvement its back to how it should be now
    hth
  1. Swirl Valve bar has come off
    By coooky in forum Engine & Drivetrain
    Last Post: 27th January 2014, 11:57
  2. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  3. Egr valve, swirl valve problems etc..
  4. Egr / swirl valve headache!!
    By Dougb in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2010, 21:10
  5. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
