Results 1 to 10 of 24
Thread: Egr / swirl valve headache!!
    salisbury
    Default Egr / swirl valve headache!!
    Can someone help with this, have had all the usual probs as listed below;
    poor power under 2500 rpm
    no spanner light
    swirl valve arm attached
    lumpy tickover until i rev it a bit.
    cleaned EGR valve and cleared 2 EGR holes in inlet manifold, boost sensor.
    Power restored for about 2 days then back to no power. I have checked the valve and sensor and all is clear, checked the swirl valve arm and that is still on although very loose and i have noticed that when the engine is running the fourth swirl valve top is slightly moving within the arm cup.
    back to square one help.
    cheers doug
    Regular Member P3tchy's Avatar
    Milton Keynes
    did you completly take the plunger out of the egr or just clean the bit you can see?
    I only cleaned the inside bit first time and it was still the same, took it apart and knocked the plunger out then cleaned it thoughly and its now spot on.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    the plunger has a tendency to corrode this was the problem i had, fitted a new unit and all is well again
    salisbury
    when i cleaned the egr the plunger ( the bit that is inside the valve? ) moved freely by thumb pressure and the solinoid was free moving.
    Regular Member OSSY's Avatar
    Apr 2009
    You said that the swirl valve rod is (on) but have you looked to see if it rotates from the 2pm to the 10pm possion whislt you rev the engine?
    It might be on, but if it does not move, the valves within your manifold MIGHT be stuck - possible fault???????????????
    salisbury
    yes the arm and the valves move and when you rev the engine they move slightly between the engine on and engine off position. while on tick over the first 3 valve top discs are still but the 4th disc is moving slightly side to side by the vibration, do you think that the bearing on that swirl has failed?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by OSSY View Post
    Correct bud or the drive module has packed up.
    Gazza4
    salisbury
    dare i say, is that a new manifold?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Dougb View Post
    Yeah but the difference is Night and Day
    Typically you get away with it but you have claimed there is a loss of power at is noticeble.
    Gazza4
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    im sorry to say..................
    but that sounds like your actuator has packed up,
    as you mentioned above, new manifold.....................
  1. Swirl Valve bar has come off
    By coooky in forum Engine & Drivetrain
    Last Post: 27th January 2014, 11:57
  2. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  3. Egr valve, swirl valve problems etc..
  4. Egr / swirl valve headache
    By Dougb in forum Engine & Drivetrain
    Last Post: 15th March 2010, 22:08
  5. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
