Thread: Wiper Blades
    Glasgow
    Default Wiper Blades
    Folks,
    i've just fitted some Halfords flat blades and now the washer jets appear to be out of sync with the wipers, i.e. the jets are striking the baldes and wiper arms rather than the windscreen? its not a huge problem as the washer fluid does eventually hit the windscreen??
    Any advice would be greatly appreciated!
    Mileage : 000
    Re aim the jets so they are a little higher than the wiper blades.
    Glasgow
    Cheers ed, i take it they are adjusted using a flat blade screw driver or simmilar? I was reading about the insignia washer jet mod and how you needed either the special tool from VX or the modified biro lid, not sure if this is the case with the vectra ones too? As you can probably tell from the daft posts, I just got my new vectra on Saturday and still trying to get my head around it! Thanks again!
    Mileage : 000
    If you have thje insignia ones . Then you WILL need a special tool. I don,t recomend tyring to adjust them with a screwdriver . You will ruin them.
    Glasgow
    Sorry Ed, i'm afriad i currently just have plain old Vectra originals! does the same still apply?
    Mileage : 000
    No you should be ok then. Get a small pin that will fit into the jet hole. With a bit of fiddling about you should be able to set the jets where you want them.
    Glasgow
    Thanks Ed, Much appreciated!
  1. Wiper blades
    By Gortreck in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2010, 09:38
  2. I need new wiper blades..
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 11:53
  3. What wiper blades should I fit
    By Shoty32 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 19:52
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
  5. New Wiper Blades
    By ballogie in forum Comedy & Humour
    Last Post: 6th February 2007, 11:02
