Thread: warning light is on
    Sep 2009
    north lanarkshire
    Eek warning light is on
    hi guys got a warning light of some sort like a light bulb with upside down question mark inside and lines round the outside of it. checked bulbs but they are ok.thanks jamie
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    light out somewhere by the sounds of it.
    i tried fitting led side lights & the car picked them up as blown very annoying
    Full Member Big Sig's Avatar
    Double check your brake lights, make sure that the same ones are lit both sides.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Check control can miraculously identify that a bulb is on it's way out...long before it actually fails.
    Strange but true!
    Could also be dodgey / dirty connection in the bulb holder.
    My front side light keeps flashing up...the glass is quite blackened, but is still working at the moment!! but I know that this will go very soon, possibly at the MOT in 3 weeks...
    Regular Member daviem-rfc's Avatar
    SUNNY DUMBARTON
    I had a brake light go on my car, I checked and both lights were on at back, turns out my rear fog was acting as a brake light in the faulty bulbs absence. Changed the brake light and problem solved
    11 Post(s)
    Quote Originally Posted by daviem-rfc View Post
    Not quite. Your car has two tail lights per side. The upper of those tail lights is also the brake light. If the upper tail light fails, then the lower tail light takes over the role of tail/brake light.
    The fog light doesn't serve any other purpose than being a fog light.
    SUNNY DUMBARTON
    My mistake but you get the idea lol
    Oct 2009
    newcastle
    Hi can anyone tell me if i will do any damage to my engine. Its a vectra 20l turbo petrol and the eml light is on, i took it to the dealer and they said its the cat. Only to find that this part nobody has one and they dont have any getting made, how on earth can this happen on a 2 and half year old car. So can anyone tell me if i will do any damage with the cat being broke and with me driving it. This is under warrenty and they say it could be months b4 i get a new one help please cheers
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it is a catalytic converter, then they should have these...even exhaust specialists should have these...
    Manufacturers are obliged to maintain a "residual" stock for at least 5 years after production of any vehicle specification has stopped...so if your model of car 2 litre petrol was manufactured until say October 2008, then Vauxhall are obliged to supply parts until October 2013.
    As for stock levels, these may get scarce if there is a sudden surge of cat failures, but as said above...Vauxhall are obliged to keep a residual stock available from their main stores for at least the next three years in your particular case.
    Regarding damaging it....then no it shouldn't damage your engine, although fuelling mixture levels may be confusing the ECU.
    Oct 2009
    newcastle
    Thanks for the reply vx did say they dont have any in and dont know when they will as nobody is making any so none in stock. Just hope its not months cheers
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vectra club warning light upside down light bulb
