Results 1 to 10 of 14
Thread: Disc Brakes
    Regular Member OSSY's Avatar
    Apr 2009
    Wink Disc Brakes
    How long should your standard disc brakes last? I bought my Vectra C 12 months ago and the disc were new all round, sorry I don't know make or model) however, I've noticed that the rear brake disc's are quite worn and so have the brake pads.
    The front disc and pads were put on at the same time but seem to be fine...
    I this normal... 12 months 13k
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    68k on both sets of mine and still going strong.
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    rear brakes should last longer as they are used less.. sometimes cheap crappy kit has been one to not last very long.. maybe an idea to get them looked at.. a new set of discs and pads from vx will only cost you £85, they are easy enough to chnage yourself if you wish to try..
    I mate of mine bought a cheap set of discs for his volvo and they last just over 300 miles...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    me and ant changed the rear discs and pads on my vec at the weekend the discs were knackered not surprising as the discs had done 100k
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    ...and I do reckon that those discs were originals too... Bloomen ek the carrier bolts were SOOO tight, they had a lot of old lock tight on the bolts.
    Advice for people changing rears - get some plus gas and spray the carrier bolts well in advance... You will also need an E18 spanner and socket and a long bar or torque wrench...
    Are you VXR Enough
    13 Post(s)
    they were tight fella wasnt they
    WGAF#5
    does ther brake compensator need adjusting? not siezed on >
    Middlesex
    Trim : SRI
    Mileage : 100k
    No - the bolts that were VERY tight were the carrier bolts that hold the carrier to the hub that once removed allow you to get the disc off.. the calliper slide bolts were fine.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Rears wear more than the fronts unusually most have said in the past!, its due to the handbrake constantly adjusting. my fronts will see 6yrs untouched!!, done the rear pads only last yr.
    Apr 2009
    Thanks for the comments and advice... getting pads changed this weekend as for the discs - will get those changed end of month...
  1. Vectra disc brakes
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2010, 11:11
  2. 314 disc and brakes
    By kenny1zero in forum Handling & Braking
    Last Post: 29th June 2008, 22:33
  3. Help with my front disc brakes
    By dave.dave100 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 12:55
  4. disc brakes
    By dan1983 in forum Handling & Braking
    Last Post: 1st December 2007, 09:50
  5. Grooved Disc Brakes
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 22:45
what torque should car disk brakes be open vectra
