Thread: HID problem
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default HID problem
    Hi Guys. Well, i just fitted my HID's and guess what i got all kinds of problems. I bought some canbus error cancellers too and fitted them also... only... one headlight still goes off after about 5 seconds. I swapped the cancellers over and the fault moved with the canceller. I removed the canceller (it was RED hot) and the light works with the engine off but not with the engine on. I also have the engine management light on i presume this is something to do with the fact that i removed the sensor cable from the airbox while fitting the HID's, as i was gonna do the airbox mod however the cover seems to be one solid peice of plastic.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    have you tried them without the cancellors? .and which kits did you buy ?
    and what actually are you saying is one solid piece of plastic ...the Airbox???
    the top of the box is held on by 5 torx screws.....do a search of the how2s i'm sure there is one about that mod
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by soulman View Post
    They are a kit off ebay and the one without the canceller on is now the one that is playing up.
    The engine management light has now gone off now and it's the airbox lid that's one solid peice but i'll have a look for the mod. cheers.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by BigWilko View Post
    OOPS! Airbox pipe is under air filter!
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    well if you got the from HIDS direct just phone them and explain and you will probibly have to return the broken one and they post quite quick ...for now you can just put your old bulb bk in .
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
