Thread: Rear Wheel Bearing (nearside)
    Full Member spennny's Avatar
    Blantyre
    Default Rear Wheel Bearing (nearside)
    How hard is this to change, MOT due next month and have a gut feeling its will fail on this
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Rear ones are easy mate, well easier than the front as of course there is no driveshaft
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Fairly easy.
    Wheel off, brake caliper off, 4 bolts from behind the hub, disconnect the ABS wiring plug (bit fiddly) and pull the whole hub outboard.
    Blantyre
    Thanks both, How much are these, Ebay or Dealers ??
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Spenny
    about £80 on the cheap,£180 ish from vx
    try autovaux in wakefield they will give you a quote online.i take it it's a C
    Regular Member Jezzy's Avatar
    S.E
    What makes you think the bearing is damaged? Droning noise?
  1. rear wheel bearing
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2011, 19:19
  2. Rear wheel bearing/hub help
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 23:38
  3. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  4. Rear wheel bearing
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 16:23
