Thread: Radio Code
    Feb 2006
    Kilmarnock
    Default Radio Code
    I'm looking to disconnect the battery to help sort out an issue however if I do will the radio lose its code.
    The reason I ask is that having got my car pass from the garage there is no radio code on it, its just blank.
    I asked about this an was told its the same as my immobiliser code, which I doubt.
    The vehicle I think had the head unit changed to the CD70 Sat Nav and I was wondering if this is why there is no Radio Code.
    Dartford
    Yeah your radio code is same as security code. Mine is... I have facelift vec c
    Feb 2006
    Kilmarnock
    Cheers,
    Wasn't wanting to go ahead and disconnect the battery and then find that it wasn't the correct code.
    Just appeared a bit funny that there was no code listed against the radio.
    6 Post(s)
    You don't need to enter a code after a power interuption. The CD70 is coded to the car and the only time it's needed is if it were divorced from the car to be transplanted into another car, and for that you'd need a Tech2 session.
    Feb 2006
    Kilmarnock
    Cheers Dave,
    Was a bit wary about disconnecting the battery and finding out that the immobiliser code was not the same as the Radio Code.
    I know I would have struggled to get Vauxhall to find the code for me as it was not in the car pass.
    6 Post(s)
    You're welcome. Don't forget to reprogramme your one touch electric windows.
  1. Radio Code
    By SarahP in forum Troubleshooting
    Last Post: 11th July 2012, 00:18
  2. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  3. Radio code
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 19:11
  4. radio code
    By farnorth in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 18:33
  5. radio code
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2007, 19:23
