Results 1 to 10 of 11
Thread: Code P1481-P1482-P1483
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Default Code P1481-P1482-P1483
    Hi,i have these 3 codes stored,P1481-P1482-P1483,all 3 are fan control 1,2 and 3,open circuit,and the spanner light is on.
    I have searched on here and using google.
    I have so far,changed the ecm,which sits between the 2 fans.
    Taken off both plugs on the engine ecu,the one under the drivers side arch liner,and sprayed them both with wd40.
    Replaced the temperature sensor.
    Checked every fuse and relay i can see on the car,taken them all out,one at a time and replaced them again,and i have had the front bumper off to check the wiring looms for any breaks.
    Taken the fuse box out and spray wd40 in that as well
    I have put power to the fans,and they spin up fine.
    I have activated the 3 control relays in the ecm using opcom,But still the spanner light stays on and the fans don't kick in when up to temperature,i guess about 90 c.
    I've tested the power at the ecm plug,and they all read 12v,but it seems like something isn't switching the 3 thin wires to earth,which should come from the engine ecu,but that would need a signal to tell it to switch them.
    Is there anything else i could try,that i may have missed ?
    Regular Member Jezzy's Avatar
    S.E
    What readings does your temperature gauge give when the engine has been running for a while?
    A Google search implies that these codes are caused by problems with the wiring for the fans.
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    It seems to fluctuate Jezzy,i changed the temperature sensor,should i have put a whole thermostat housing on instead ?
    I didn't think it would have made a difference,as when the temperature gets up to 90 c or slightly above(when i tried it for test purposes),the cooling fan doesn't kick in.
    Glasgow
    What are you using to read the codes? If your not using op-com maybe a member around your area could plug in there op-com and do a test on each of the fans and have a look at what the sensors are saying.
    Admin plasma's Avatar
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    Check wiring which runs near the nearside wing, think they can chafe through. Had this problem before with Kman's car and had to run seperate cables to repair it
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    I am using opcom,i've even plugged tech 2 into it,but i'n no wiz on the computers,lol
    I managed to go to the screen where you can activate things and i activated all 3 control relays,one at a time is all it would let me do though,but still no fan.
    Glasgow
    Ah right, if there not coming on i would go with what the others are saying about damaged wiring.
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by plasma View Post
    Was Kman's fault the same thing P1481-p1482-p1483 ?
    I did have a look at as much wiring as i could while the fuse box was out
    I'm getting 12 volt power to all the ecm plug sockets,the 3 little wires are just not being switched to earth i think the problem is,but i'm not a no it all,so all input is very welcome,thankyou
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Morning all. Is the writing for this handy enough to get to. Having this portion also, but mainly in damp wet weather, which leads me to believe its the writing chafed through.
    milton keynes
    try to spray wd40 on to your engine ecu contacts
  1. P1481 fault code
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 13th January 2016, 23:09
  2. p1481,p1482,p1483.
    By jimmyred in forum Engine & Drivetrain
    Last Post: 6th June 2015, 21:41
  3. Fault Code P1483
    By chas901 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th December 2012, 17:41
  4. Error CODE P1482
    By Bikedylan in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2011, 11:16
  5. Fault code P1482
    By tridley in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2011, 17:39
p1482 corsa
p1482 opel vectra c
p1483 code
p1481 p1482
corsa c p1482
vectra c p1482
