Thread: tyre size change
    mars
    Default tyre size change
    Hi guys
    i have 215/50/17 all round and the fronts are due to be replaced with in a month or two. i was thinking of upping the width size on the back but unsure how wide i can go and not looking to silly.
    225/45/17 will fit nicely, although I believe nutron fitted 235's - just!
    mars
    Thanks thats what i was hoping for 225 not to sure with the 45 for every day use.
    mars
    Quote Originally Posted by gaby19uk View Post
    The "45" profile is a percentage of the tyres width, not a set height, so its actually very similar to a 215/50 profile tyre.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    11 Post(s)
    See a previous post of mine showing 215/50/17's (NCT5) on the rear, and 225/45/17's (Rainsports) on the front
    http://www.vectra-c.com/forum/showthread.php?p=956935
    As Big Sig says, there's hardly any difference.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    not bein a tyre expert ,i want to ask a question and im will probably sound stupid.
    i got 215/50/17 ok
    now some ppl have said that you can fit 224/45/17 with HARDLY any difference .
    hardly is the key word in the fact that there IS a difference then ,
    so can i ask what is the difference .
    i thought that 45s are 5mm smaller than 50s on the side wall
    yes no?????
    help and advise wud be gr8
    Quote Originally Posted by myelite150 View Post
    i got 215/50/17 ok
    yes no?????
    No, if you read the above posts and try the calc that has been put up you would see its a ratio of the width. Overall its 13mm difference in diameter (you really cannot see it), and yes before you ask, the 225's are an alternative size for the vec/siggy as in the hand book.
    Nov 2009
    south wales,Cwmbran
    ok thanks for that
    but i feels like i was bein told off
  1. Tyre Size change - Yep, yet another thread about this!
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 12:32
  2. Tyre Size Change..
    By macdad in forum Handling & Braking
    Last Post: 19th February 2010, 23:03
  3. Tyre size change knackered my MPG!!
    By Last Turkey in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 12:32
  4. Tyre Size Change...
    By macdad in forum General Chat
    Last Post: 6th October 2009, 21:09
  5. Tyre size change question...
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 23:00
