Results 1 to 2 of 2
Thread: Help with car
    Regular Member eaglepva's Avatar
    Up North
    Default Help with car
    Hi,
    Been having problems again with my signum DTI. The car runs ok but every now and again i get a slight misfire/judder when driving along. then when i come to stop the revs will be bouncing up and down and the car tries to stall but doesnt just keeps doing it and the revs bounce up and down and their is grey smoke coming out the exhausts. If you give it a couple of revs it sometimes clears it and its ok for a while. i have cleaned the EGR valve and the manifold. When its playing up if i pull out the MAF plug the engine instanly changes to normal idle.
    I have just had the car on a code reader but no codes were present.
    Any help/suggestions appreciated.
    Ash
    Regular Member smithy21's Avatar
    Jan 2010
    romford essex
    i had a similar problem on a ford focus once it turned out to be a faulty injector!
