Results 1 to 3 of 3
Thread: Washers
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    Default Washers
    Think this is in the right section...
    My washers havent been working for a while now so did a search and found the little gromit thats usually blocked up... But when i pulled it out it seems the bright spark of a previous owner decided it would be a good idea to cut the filter part of it off
    I then ran the pump from a bucket and its only just poring a little water out the washers so it is still working but is there any way i can try and clear the gunk out? would filling the bucket with boiling water then using the boiling water clear out the gunk or not?
    Any and all help will be much appreciated!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, disconnect the pipes at the jet end and pump and blow down them 'the right way' to see if they are blocked, if not then blow through the pump 'the wrong way' and see if anything blows out. You won't be able to blow much through the pipes 'the wrong way' unless you disconnect any one way valves that are fitted.
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    I actually never thought of that
    Il give it a go tomorrow morning. Thanks
  1. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  2. Got some new washers
    By lizard in forum Handling & Braking
    Last Post: 12th September 2009, 20:04
  3. headlight washers.
    By Netstar in forum Bodywork & Interior
    Last Post: 2nd March 2009, 16:18
  4. help with washers
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2008, 14:03
