Results 1 to 2 of 2
Thread: Brake light broblem
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Default Brake light broblem
    Just changed the front side light bulbs after a blown bulb. Everything went well, but now im getting the message turn signal failure. Indicate left and the front and side indicator flash at 100mph, the rear does not flash at all, I've changed this rear brake bulb twice with no change. However I've also noticed that the right and high level brake light dont work when braking and no warning about them on the display either, again bulbs are fine, any ideas before I go mad and take it to the dealers?
    thanks in advance guys, oh and fuses seem fine
    Nov 2007
    Aberdeenshire
    Quick update guys, the left hand cluster is using another bulb to act as brake, the right hand side and spoiler brake light still not working, reset ECU by disconnecting battery, still "Turn Signal Lamp" message on display but no blown bulb icon on instrument cluster, garage wont look till fri, any help would be greatly appreciated
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
brake light flashes when indicating vectra c
