Results 1 to 10 of 14
Thread: Random starting problem
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default Random starting problem
    Hi guys i have a random problem at the moment sometimes after a drive and i leave car for an hour and come back car will turn and turn but no sign of life what so ever,no attempt to fire up
    Now i know my battery's knackered coz after a couple of turns it starts to slow down so i stop leave it a minute then turn key and it starts 1st time with a cloud of white/greyish smoke
    Any idea's i was going to do leak off pipes this week but could it be anything else ?
    Remember this only happens now and again in last month id say twice or three times max,car was on flat surface at the time
    Irmscher Insignia CDTI 130
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Glow plugs spring to mind,
    But if your battreys knackered it could just need a new battrey
    i had a similar problem with my bike the battery showed good volts but it had no AMP's to turn the engine
    a new battery fixed the bike £65
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by Thunder View Post
    Would Glow plugs matter if it wasn't cold enough ? car starts fine in mornings but i do get some white/grey smoke and it smells of diesel.All though if i sit there and turn key on and off about 3 or 4 times to heat glow plugs up it starts with no smoke
    Battery is dieing though ever since i ran out of diesel a while back and i was turning car over and over,now after a few turns it starts to slow
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Just went and checked battery
    12.28 not started
    14.18 started going up to 14.38 when revved and lights on
    Had this problem before battery started dieing though
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    could you give your battrey a good charge & see if that helps
    glow plugs was the first thing that pop into my head lol
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    i pop a search into google & it came back to vectra c.com but all for the 2.0 dti
    link 1
    link 2
    it seems
    most likely due to old leak off pipes or worn injector seals...allowing air into the system and causing fuel to drain out of engine back to tank
    this maybe the problem
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sunny Dartmoor
    I'd say battery Don,how old is it????
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Whats the cranking voltage mate? Mine was well over 12V, ran well over 14v when running but only cranked at about 9.5V. Mark (3.2GSI) recommended at least 11V cranking drop. New 72ah battery and all has been fine and no starting probs. It seams to be not enough power to trigger the starter solenoid, so all you get is a tic tic tic as you turn the key. My previous battery was only 6 months old but not a very big one.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by glenboy View Post
    Not sure mate its a genuine vauxhall one though
    Mine turns mate just wont start but its completely random,just tried starting it a minute ago and its been sat outside my house for a good few hours and it started 1st time with a little bit of white/greyish smoke
  1. starting problem!!!
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2009, 20:06
  2. Problem...? Vectra SXI...problem with starting after filling with fuel?
  3. Random electrical problem
    By penfold2000 in forum Engine & Drivetrain
    Last Post: 29th April 2008, 00:34
  4. Random Corsa C "Not Starting"
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 19:03
  5. Starting problem
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2006, 10:02
