Results 1 to 10 of 15
Thread: mot comming up ans abs light
    Glasgow
    Default mot comming up ans abs light
    right guys my abs light and traction has been on for ages now.
    when changing all my bushes etc i went round all the connectors and wd40'd it but made no diff, i have the passenger side bearing changed as i was told that was the problem but it didnt solve the problem.
    it started in the cold weather when i was driving to my work i didnt notice the light was on untill i got their, i went into my work and came out thens started the car and the light was out, then it came on again and stayed on.
    the garage told me it was either that side as it was showing no signal or sumthing or the abs unit was gubbed.
    the only problem i have is it needs to be vauxhall to tell me the real problem and if it is the abs unit then it needs to be vauxhall who program it in!
    so could be expensive.
    i checked the plugs in the engine bay and nothing unusualo.
    any suggestions?
    get the codes read correctly as you seem to have done the basics.
    May 2008
    saltburn-by-the-sea
    did u get it sorted mate because mine is exactly the same and i need to sort it
    11 Post(s)
    Quote Originally Posted by swanny00 View Post
    As said, get the fault code(s) read out.
    Glasgow
    no mate not got round to it, vauxhall want £80 to read the damn code, im gonna pull the wheel linning back and check the cables before i go to them..
    11 Post(s)
    Doesn't have to be Vauxhall. Most garages these days have code readers and will do it for a fraction that Vauxhall want.
    Apr 2008
    murton seaham
    my abs light came on when bearing was changed this is as i found out because it was an after market bearing kit so got a genuine one plugged it in first and light went straight off so might be a good idea to borrow one from vauxhall for a test it might work as it did with mine good luck hope this helps
    Glasgow
    thats funny you should say that about after market parts, i got a hub from a local place and it was £150! but didnt solve the issue.
    so any garage will do the test? i thought it was vauxhall only! thank god!
    im gonna have a look at the car tomorrow morning, i'll keep u upto date lads.
    Glasgow
    well guys checked all the cables and all seems well, so i think the garage is the only damn options!
    Regular Member mark1976's Avatar
    Barrow on Humber
    Hi mate, try checking the wiring to n/s/f again, vectras are quite prone to water ingress between the connector inside the wheelarch and the hub. If you strip back the outer cabling you will prob find there is a corroded bit about half way along, you will know it when you see it cos it will probably be a bit green. HTH.
  1. Constant air comming through vents
    By justin33 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th November 2012, 18:26
  2. With winter comming, grab a bargin!
    By Kenny_Exclusiv in forum West Scotland
    Last Post: 23rd October 2012, 22:34
  3. someone comming to view my vec at 12 eek!
    By Morephun in forum The 'Off Topic' room
    Last Post: 14th May 2010, 22:09
  4. spanner light comming on but goes off its self
    By peadar in forum Engine & Drivetrain
    Last Post: 4th October 2008, 07:43
  5. Frame Tent - summer meets are comming
    By jonnye in forum General items for sale
    Last Post: 10th April 2007, 20:24
