Thread: engine light on loss of power
    WIGAN
    Default engine light on loss of power
    just had the symbol of the engine (emisions light ) come on this morning on a 150 sri 97 vectra , seems to be low in power aswell any ideas ?
    If its under warranty get it booked in
    WIGAN
    it juist out by a month
    Edinburgh
    I'm guessing you me 07 then rather than 97
    WIGAN
    yes 07 sorry
    EVERYWHERE
    You need to get the codes read. You can take it to a garage or get your own code reader.
    Usual problems include EGR valve, swirl flaps, numerous sensors.......
    Being only a month out of warranty may get you some 'good will' treatment from VX.
    WIGAN
    just been for a spin in it and it seems like i cant get past 50 in 4th have to change up to 5th to get past that up to 65 and 6th to get up to 70+ any more ideas
    Essex
    Could be a guess but I had something a little like this on my Galaxy. For that it was the Mass Airflow Sensor. Car wouldn't rev beyond 3000rpm. That would sound about right for 50 MPH in 4th ?
    11 Post(s)
    Quote Originally Posted by DonZ1000 View Post
    any more ideas
    Quote Originally Posted by diesel dog View Post
    You need to get the codes read. .
    Takes all the effort out of guessing what's wrong.
    WIGAN
    had it put on the test unit last night came up with swirl unit fault, garage said it need new manifold as it was knackerd, took it home to take a look and noticed that the butterfly bar was sticking loads of crap round the plastic so cleaned it all up gave it a lube with some teflon spray started and stopped the motor about 10 times and it seemed to clear up not sticking any longer and drives like a dream again, also light rest its self after a quick run round stop and restart of engine , amazed it worked but only time will tell.. thanks to all for your replies..
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. major power loss and engine noise
    By martin.lake in forum Engine & Drivetrain
    Last Post: 17th September 2012, 00:13
  3. Loss of Engine power
    By Billythebubble in forum Engine & Drivetrain
    Last Post: 22nd December 2011, 23:07
  4. Loss of power and engine judder in 5th and 6th
    By gdansk in forum Engine & Drivetrain
    Last Post: 23rd September 2011, 15:08
  5. Idle problem, loss of power, engine management light on.
    By Coyney in forum Engine & Drivetrain
    Last Post: 10th July 2011, 10:57
