Thread: Running Noise
    Staffs
    Default Running Noise
    My 52 plate 1.8 vectra has developed a noise when the car is moving 30 or above, the noise is at its loudest about 45 but can be heard constant at any speed over 30.
    It sounds like big chunky tyres on a concrete road surface, my vectra is driven on tarmac with normal road tyres!!
    I tried coasting to see if the noise was linked to engine revs, but it reamined when the revs had dropped off.
    Any thoughts gratefully received.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    did you knock it out of gear and coast?
    Regular Member yzf1kr's Avatar
    Netherlands
    Staffs
    I coasted via clutch to the floor, I did not take the car out of gear
    Are you VXR Enough
    13 Post(s)
    coast with it out of gear and clutch pressed down
    Nov 2009
    Luton
    sounds like a wheel bearing to be honest
    Staffs
    Tried the coasting with clutch out, car out of gear. No different.......
    Are you VXR Enough
    13 Post(s)
    what tyres are you using
    Regular Member killer_bunny's Avatar
    Jan 2010
    leeds
    wheel bearings
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. pay for someone running in to u
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2006, 16:14
  4. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
  5. Running in?
    By sharpy in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2006, 18:00
