Thread: Sport switch
    Regular Member tditony's Avatar
    durham
    Vehicle : 2007 sri xpnav
    Trim : sri xpnav
    Engine : 1.9 150
    Default Sport switch
    Does anyone know what the pin outs on the switch are im wanting to wire it up for my tuning box switch any help would be greatly appreciated thanks in advance
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I was looking into this too mate, i believe I need a latching relay to do it though. May look for another kind of mechanical sport switch
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the sport switch is the "Semi-Active Damping" switch, then the pins are: -
    There is no mention of SPORT switch on the TIS wiring diagrams, however this switch does affect the "settings" of the suspension on the rear stub axles.
    pin 1 - Blue/white to BCM pin 71 = Funtion is "On" warning light on switch.
    pin 2 - Grey/Yellow to BCM = Back lighting wire
    pin 5 - Brown = Switch and illumination Ground
    pin 6 - blue/yellow to BCM pin 70 = On/Off momentary contact switch
    Regarding switching an external device, then you would indeed need to run the switch in conjunction with a latching relay.
    The complex bit is to get the relay to unlatch from the same inpulse voltage / switch....needs a little fiddly circuit to flip-flop the latching / unlatching circuit.
    Sunny Dartmoor
    Quote Originally Posted by Robsey View Post
    To have it just light up do i just connect pin 2 to earth and 5 to ignition live then??????
    Hope so,sure someone already did this but couldn't find it............
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes, just connect up the grey/ yellow to a light feed or to the same colour wire of a neighbouring switch and then connect the brown to a good earth.
    Take the blank out and see if the connector is already there.
    If it is, then it's just plug and play...sometimes these connectors are in, just not connected for function, or not programmed in.
    Same situation as the ESP switch usually.
    I put the ESP / TC switch in my car for the "look" of it...the switch lights up, but doesn't do anything in my case.
    Sunny Dartmoor
    Cheers Robsey
    I fitted the sport switch and it lights up but when i fitted the sport button it doesn't,so i'll give it a go.............
  1. Sport Switch / ESP
    By Vec_elite in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2011, 13:29
  2. Sport switch
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2011, 23:46
  3. Sport switch again (sorry)
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2009, 14:38
  4. Sport switch?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2007, 08:55
