Thread: rear brake piston rewind
    Aberdeen
    Default rear brake piston rewind
    vectra 1.8 sri 07/07
    hiya i am new to here and have had a good look about. i am trying to change my back pads and disks. yesterday i jacked up my car and took wheels off and dismantled the brakes. but i spent most of yesterday and all of today going round aberdeen trying to get a piston rewind tool. i bought 3 all of which don't fit. so this afternoon i made my own. but i am yet to try it. the question i have is, do i have to clamp the brake fluid hose and open bleed nipple once i start screwing piston back in ? or do i just open reservoircap and start screwing piston back in ?
    thanks
    Paul
    Regular Member RobW's Avatar
    Tain - Easter Ross
    I just opened resevoir cap and used fine nosed pliers.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Aberdeen
    Default ok done that
    ok its all back together again lol. now i got to drive to work. am 5 hours late. and wasted all weekend looking for a windup tool that fitted yet took me only 5 mins to make the bit that fitted. i let ya know how breaks go. thanks
    dudley
    clamp the hose, fit a one man brake bleed kit to the nipple and loosen the nut off, the bleed kits worth everyone of the £5 it costs from halfords, stops air going in and means you can see when the oil comes out so you can see you efforts working. makes winding the piston in alot easier this way, I used this method and long nosed pliers, and a small headed 10mm spanner for the bleed nipple and it took only 5 minutes to wind the piston back,
    I thought that pushing the fluid back through the system was bad news for the abs unit, hence why the book says you clamp and bleed the excess out the nipple. I might be wrong but the above is the haynes suggested method, it worked fine for me.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I've never clamped and released the brake fluid. Unless you are a handfisted baffoon there really shouldn't be any issues. Also, no need to bleed the brakes afterwards and no need to replenish the lost fluid.
  1. Brake piston/rewind tool
    By 123rado in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2012, 12:04
  2. seased rear brake piston
    By leedrummond in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2012, 20:07
  3. brake rewind piston tool details
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2011, 10:53
  4. Brake Piston Rewind Tool - Which One?
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 19:17
  5. rear brake piston
    By guitarbaz in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2010, 16:44
vectra rear brakes no abs rewinder
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
