Thread: Here's another 1 for ya
    Aldermaston (Berks)
    Default Here's another 1 for ya
    Me again lol, sorry for all the questions i know sweet fa about diesels, somewhat of a learning curve.
    Been reading up on the glow plug light threads, this morning where i live it was -4 & no glow plug light.
    However by removing the engine temp sensor plug seems to fool the car into thinking it must be cold and i now have the glow plug light on & the spanner (to be expected).
    What would be the effects of a faulty engine temp sensor, could this throw out fuel economy - starting issue's as mentioned in my previous thread.
    I the e.g.r is over due a clean, basically the whole car needs a service tbh, i will start with the basics to eliminate low down poor power.
    Could someone please enlighten me if the engine sensor would cause some of the above faults.
    Thanks again.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    How did it start up presuming the glow plugs did not work?, it may pay to check the glow plugs anyway, some vx diesel glow plugs dont come on till -3, you can test with a meter or you can remove them test by gripping the nut with earth jump lead connected to battery, and touch live on the screw thread, only till they start to heat up proving there ok, you could have a faulty eng temp sensor but at least you would be knowing the glows are good.
    Aldermaston (Berks)
    Thanks for that, great idea. funnily enough when leaving work the glow plug light did light up briefly, maybe looking at the plug on the loom. For peace of mind though i will change the engine temp sensor & check the g/plugs.Liking the idea with the jump leads lol wicked.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You didn't say what engine it was?, Even my cdti only lights up briefly!!, But that does not mean there not working!, The glow plugs will still heat up for '5 seconds at 11v then a further 7 seconds at 6v' (for example), most people think if the light's not on they aren't working, But its not always so!, as said most systems have a step down voltage as above even when you drive off.
    Aldermaston (Berks)
    my bad, 2.2 dti lol.
